Found it.
PLAY STYLE
Overwatch
Average kill distance
54 m
I don't see what the play style is based on though. :\
Found it.
PLAY STYLE
Overwatch
54 m
Mine says Commando. I have 100% Tactical Planning and 64% Stealth Kills.
Which makes sense, I always use my drone to scout out an area first and then I move in with trying to not be seen. But sometimes you gotta <vazquez>LET'S ROCK!</vazquez>
Edit: I'm a little disappointed they don't have stats for each of my characters. I was planning on playing the game someday where if I got killed I would start over.
Edit2: Also, if you want a more immersive feel to the game, turn off the HUD. I only have the Gun and Ammo graphic on and that is because I can't tell which item I have selected; grenade, mine, C4 etc. I wish they had it flash up for a split second when I picked the item when I have the graphic turned off. Doesn't seem like it changes what you have in your hand but maybe it does, just sometimes it is hard to see what you are using. In real life you would know.
I like having all the info.
That website is so bad...
Join us
https://ghostreconnetwork.ubi.com/en...073/GTXF-Squad
I typically use my silenced pistol for stealth kills and then keep my assault rifle unsilenced for when things go loud.
I wonder if that (plus dying too much) is what is giving me "Grunt"?
I'm surprised I'm not a grunt with how often I'm on the .50 cal.
I should be listed as "it's complicated"
I have a problem. #Rambo
Working with Kid on my low-level 'toon last night, I died a lot. I'm still having fun but my higher-level character is noticeably tougher than the scrub -- to the point that I regret putting any Skill Points anywhere else but in toughness perks!
Was just doing a little light reading at the Wildlands Reddit. People have discovered an issue where if I join a friend that is taking down a Buchon/Boss and I have not unlocked that mission then I don't get the skill points for finishing the Buchon/Boss mission. Wowza!
Luckily I have basically not played any Boss missions with my friends. Shit, I've hardly played any missions with my friends. Just been running around collecting stuff and causing mayhem.
Well set your XBL profile back to "Online" and we'll invite you!
Why would he do that when he can use that AI sync shot cheese?
