It's still pointing towards the disk.
Was SSD connected when booting from HDD?
Was HDD in earlier SSD connector?
If so then try different one.
You can't write ECC errors, or any errors, so it's tilting to mobo's direction.
Quite odd anyway.
Is it possible that the machine has a small cache ssd somewhere?
ps.
just few days ago I found a disk that had mostly every 255th block in error state.
Wouldn't I see other issues if it was the motherboard? I mean I have run and accessed things off of my other drives without issue. Literally the only thing on my SSD has been Windows and a small number of programs (Antivirus, and such tools) everything else is ran off of the D and E drives. Also not surprised that the one named Blizzaga is the one slowing down...
It could be those ports in particular.
well, next step probably should be a clean install I think, I mean i could change cables around. I mean everything worked fine till Windows updated on Oct 25th
Do four HDD speed tests.
Drive as a system and data disk with original and different connection.
I don't have time for a reboot this morning so.
Crucial M4 SSD - System
Sequential Read (Q= 32,T= 1) : 5530.464 MB/s
Sequential Write (Q= 32,T= 1) : 2162.220 MB/s
Random Read 4KiB (Q= 32,T= 1) : 1508.719 MB/s [368339.6 IOPS]
Random Write 4KiB (Q= 32,T= 1) : 1337.348 MB/s [326501.0 IOPS]
Sequential Read (T= 1) : 5294.273 MB/s
Sequential Write (T= 1) : 2139.869 MB/s
Random Read 4KiB (Q= 1,T= 1) : 288.145 MB/s [ 70347.9 IOPS]
Random Write 4KiB (Q= 1,T= 1) : 1005.619 MB/s [245512.5 IOPS]
Hitachi Deskstar (Clone drive)
Sequential Read (Q= 32,T= 1) : 1334.378 MB/s
Sequential Write (Q= 32,T= 1) : 1309.294 MB/s
Random Read 4KiB (Q= 32,T= 1) : 10.171 MB/s [ 2483.2 IOPS]
Random Write 4KiB (Q= 32,T= 1) : 11.010 MB/s [ 2688.0 IOPS]
Sequential Read (T= 1) : 996.229 MB/s
Sequential Write (T= 1) : 1308.718 MB/s
Random Read 4KiB (Q= 1,T= 1) : 5.243 MB/s [ 1280.0 IOPS]
Random Write 4KiB (Q= 1,T= 1) : 10.842 MB/s [ 2647.0 IOPS]
WD Black (Main storage drive, more or less did this for more info)
Sequential Read (Q= 32,T= 1) : 1171.272 MB/s
Sequential Write (Q= 32,T= 1) : 1178.988 MB/s
Random Read 4KiB (Q= 32,T= 1) : 10.834 MB/s [ 2645.0 IOPS]
Random Write 4KiB (Q= 32,T= 1) : 10.470 MB/s [ 2556.2 IOPS]
Sequential Read (T= 1) : 1175.223 MB/s
Sequential Write (T= 1) : 1152.652 MB/s
Random Read 4KiB (Q= 1,T= 1) : 4.899 MB/s [ 1196.0 IOPS]
Random Write 4KiB (Q= 1,T= 1) : 10.605 MB/s [ 2589.1 IOPS]
now, wtf does this mean?
That both your hard disks are operating at a similar speed, and that your SSD is much faster than both of them?
Seriously - I'd swap the ports around. As in: If SSD and HDD1 are connected to Ports 1 and 2, try and connect them to Ports 3 and 4 respectively (if you them). It's rare for MBs/Ports to go bad, but it does happen.
