Results 1 to 3 of 3
Thread: What has 4 wheels, 1 big fan, design by Gordon Murray and is not a BT46?
    A GMA T.50 A fan car for the wealthy!
    Gordon Murray Automotive – T.50 – Technical specification
    Configuration
    Supercar with GT capability
    Coupé – central driving position
    Dimensions
    Length: 4,349 mm
    Width: 1,850 mm
    Height: 1,152 mm
    Wheelbase: 2,700 mm
    Front track: 1,586 mm
    Rear track: 1,525 mm
    Weight: 980 kg
    Chassis / Body
    Full carbon fibre pre-preg monocoque, carbon fibre body
    Engine
    Type / number: Cosworth GMA
    Configuration: V12 semi-structural
    V. angle: 65°
    Displacement: 3,994 cc
    Valve train: Double overhead camshafts / variable valve timing / 4 valves per cylinder
    Lubrication system: Dry sump
    Maximum power: 650 hp
    Maximum torque: 450 Nm
    Maximum rpm: 12,100 rpm
    Starter: 48-volt integrated starter
    Alternator: 48-volt ISG (integrated starter-generator)
    Transmission
    Configuration: Transverse all synchro constant mesh
    Speeds: 6 forward and reverse
    Gear selection: Manual with reverse lockout
    Suspension
    Front: Double wishbone with anti-roll bar
    Rear: Double wishbone – included axis GSP system
    Steering
    TypeRack and pinion with LSPA
    Aerodynamics
    Full ground-effect with fan-assisted boundary-layer control
    6 aero modes
    I wish I could post the official Hi-res images but I don't know how.
    Why won't they make it a hybrid? It makes no sense for a start-up to put up with such a big tax hit.
    There’s a thread here for it my friend.
    http://gtxforums.net/showthread.php?1940-T-50
    Russ!!
