Originally Posted by
thesameguy
Another question for FIL: I need to drill about 28 3/8" or 7/16" holes in a beam that is comprised of two 2x6s fixed together. The issue is that one side of the beam twists or tilts on its vertical access - eg, the top of the beam leans away. I was going to acquire my first set of spade bits for this project, but I am concerned that spade bits will follow the tilt, which is not desirable. I need the holes to be perfectly parallel to the ground. Is this not actually a problem, is there a way to solve this, or just use normal twist bits?
