May 31st, 2014, 01:13 PM
#41
umm....take it apart and eliminate the LED.
May 31st, 2014, 02:05 PM
#42
Tried, but it's sealed shut. I don't think it would survive the dismantling and still be panel mountable. I was hoping it was just clipped or screwed shut, but no such luck. Believe you me, when something doesn't work my first reaction is to dismantle it.
May 31st, 2014, 03:27 PM
#43
Lol, I forgot who I was talking to.
May 31st, 2014, 11:30 PM
#44
Sometimes I dismantle things even when they're not broken.
I'm going with the Pioneer x560bt for the Southwind, the same stereo I put in the Benz. It's $105 on Amazon, which is bloody cheap. I'll probably need an amp which offsets the savings vs the JVC, but $250 for 50w+ RMS or $190 for 22w RMS makes the extra $60 seem reasonably worth it. These are literally the only two currently made stereos with rear aux inputs.
I am slightly torn on speakers - I have zero depth limitations but minor height limitations due to the grills. I also have significant financial limitations - I'm not going to spend hundreds of dollars on these speakers. I think it's down to either JBL or Infinity Reference
http://www.amazon.com/Infinity-Refer...ference+6032si
http://www.amazon.com/JBL-GTO628-6-5...rds=jbl+gto629
I'm going to see how the thing sounds with stereo power before investing in an amp as the current setup is decent, but I think I'm going to want an amp. I do have an ancient and gigantic 5-channel Sony in the garage I might be able to use... Crazy as it sounds, it may not fit. Well, may not fit without a LOT of work.
June 1st, 2014, 11:25 AM
#45
Miracle of miracles, not only does Ye Olde Sony Ampe *barely* fit in one of the overhead compartments, but there is a wire channel running up the a-pillar right to it. I think I'm going to roll with it, as I just can't see ever using this amp again - it has an 11x17 footprint, which is *ginormous* by modern standards, especially given its modest 4x40+100w output. Yeah, that's right - it's a 5-channel amp. Makes me want to wall off the adjacent compartment and use it to drive an 8" mid/sub, but I'm not going to. I am running out of energy on this project.
This is the amp: http://www.crutchfield.com/S-zSkggEk...XM-405EQX.html
I am now seriously thinking about ganking the stereo out of the SPG. It's overkill feature-wise for this application, but OTOH I'm always up for buying a new stereo, and the newness more or less gets wasted in the Southwind.
June 1st, 2014, 12:33 PM
#46
Scratch that - the stereo in the SPG has a front aux in. DOH!
June 2nd, 2014, 09:46 AM
#47
I ended up going with these speakers:
http://www.amazon.com/Rockford-Fosga...d+fosgate+p165
ATM, I don't remember why I chose them over the Infinity or JBLs.
June 2nd, 2014, 12:20 PM
#48
June 2nd, 2014, 02:41 PM
#49
They're the same price as the other two - all about $50/pr. The next jump in quality brought things up to $100/pr, and I just can't believe that price bump would be justified in the listening environment I'm talking about.
June 2nd, 2014, 03:09 PM
#50
It isn't. I keep tossing the idea of doing a complete system in the Yukon. Then I realise that it is a winter "beater" and a tow rig. No sense in wasting 1-2k on a great stereo setup when the shitty bose will do.
I just need a better HU
