Page 42 of 53 FirstFirst ... 32404142434452 ... LastLast
Results 411 to 420 of 527
Thread: C7 Corvette Updates/Info
  1. #411
    Most likely the ZR1, bet it will be called the LT5.
  2. #412
    I'd think that would be for the mid-engine car. Especially with the additional info in that article.
    Interesting the C4 ZR-1 had a DOHC, didn't know that.
  3. #413
    Quote Originally Posted by Freude am Fahren View Post
    Designed by Lotus, built by Mercury Marine. Only DOHC V8 GM has ever built. ALso fit in the footprint of the SBC. Brilliant engine.
  4. #414
    Quote Originally Posted by Godson View Post
    <cough> Northstar<cough>
  5. #415
    We don't talk about the northstar.
    Design attributes of that engine are nightmarish. If you pull both heads off the engine, you drop the mains caps and the crank is now only supported by the oil pan.only way to put main caps back on is to drop the oil pan. You see where I am going with this. And before you say the heads dont have issues, these engines pop HGs like I have been having surgeries.
  6. #416
    That's nightmarish
  7. #417
    It is one of the few V8s that drops into the DMC rather easily.
  8. #418
    So, so hawt.
    Attached Images Attached Images
  9. #419
    16 fuel injectors, two stage throttle body, all internals are forged.
    The only weak part of that engine is the thermostat housing. When the thermostat fails, you have to pull the thermostat housing apart, as it is not on the engine block. The bolts are almost guaranteed to be seized in the housing and them breaking. New housings from GM don't exist. NOS is impossible to find.
    The current solution is a CNC billet housing that costs 700$ last time I checked.
  10. #420
    ZR1 and Mid-Engine C8 Corvettes Spied Together in Cold-Weather Tests http://bit.ly/2kNkRW7
