Page 12 of 13 FirstFirst ... 210111213 LastLast
Results 111 to 120 of 126
Thread: Rich's 2016 FiST of d00m
  1. #111
    They're fine. I got lucky.
  2. #112
    Put the summer tires on about a month ago. Took her to Tire Rack to get the TPMS sensors "relearned". Two(LF/RR) wouldn't sync. Took it to the dealer and they replaced the LF sensor and it still didn't work. Took it back to the dealer and they decided that the body control module was shot. They ordered one and told me to drop in any time, but not around 5 PM as that would be inconvenient. So after working six days this past week, hopefully this Tuesday it will be fixed for good.
  3. #113
    Body Control Module switched out yesterday. Today on mile 15 of the drive to work(when I came to the same spot where every day I'd get a message saying "TPMS error" or "TPMS sensors not found") nothing happened(which is a great thing).
  4. #114
    Dead Brand Ambassador dodint's Avatar
  5. #115
    Pretty much. Dealer called today to make sure if everything was good and to see if I had filled out the survey they had sent me. This dealer seems to be fixated on these surveys and making sure they get only excellent scores.
  6. #116
    BMW does it too.
  7. #117
    Scotland
    Dealers are under major pressure from brands. If you told someone about your dealer giving you bad service, would you use the dealer by name or just say 'The Ford dealer' or 'XX Ford' which then reflects badly on the brand more than the dealer themselves. Customer Satisfaction scores and 'Net promotor Scores' (NPS) are king these days.
  8. #118
    Looks like the turbo on my work truck('15 Hino) is dying. At least it lasted 172k miles.
  9. #119
    Consultant KillerB's Avatar
    Cypress, CA USA
    So I thought it was a done deal that we're never getting the new FiST, but I keep hearing that Ford crash tested the Fiesta body and so might bring over just the FiST because apparently the engine is being used in some gross subcompact CUV or something. Any truth to that, SLM?
  10. #120
    The Eco(ECHO)sport(which may be the "gross" CUV you're referring to) gets a 1L I-3 and a 2L I-4. It also weighs 3000-3300 lbs. Not sure how the acceleration is, but I can't imagine it being too swift, unless you've always got your foot into it.
