April 14th, 2016, 12:52 AM
#181
Yeah, owned it for 10 of the past 13 years ... I sold it, and bought it back again a couple years later.
Then proceeded to sink stupid amounts of money into it.
April 16th, 2016, 01:15 AM
#182
Old engine out. New engine in the hole, but not hooked up
April 16th, 2016, 09:39 PM
#183
It's adorable!
April 17th, 2016, 10:58 AM
#184
New engine in and running.
But is running flat as a pancake, which my mechanic thinks is probably down to timing.
Normally that isn't an issue, because all you do is bridge two ports on the diagnostic port, and you can set the base timing. However as my car was a 16 valve 4age, and has had a 20 valve 4age transplanted into it, with accompanying alterations to wiring. So my mechanic is going to need to consult my auto sparky as to what he'd done to allow timing to be set (rather than monkey about further).
So the new engine has mildly bumpy cams, and slightly better extractors on it. This means I'm hoping for a slightly better power delivery out of it (when of course it is actually going properly). Fingers very much crossed here.
April 18th, 2016, 06:23 PM
#185
Driver
Two thumbs up for 20V goodness.
April 18th, 2016, 11:07 PM
#186
Agreed.
To clarify, the current engine, and the engine for the previous 10 years is 20v The 16v original went "knock knock" at a racetrack after two years of competition, which is incredibly common.
April 19th, 2016, 01:47 PM
#187
Driver
Yep, I remember, but still have a bit of 20V envy here, refreshed just as your motor is.
April 21st, 2016, 12:46 AM
#188
The car is apparently now all timed up, and going well.
I'm not able to get the car back until Saturday, so I'll be taking it out for a drive then
April 22nd, 2016, 09:32 PM
#189
Car goes much better. However is still smoky after long trailing throttle. Hopefully this calms down as rings bed in.
May 8th, 2016, 02:10 AM
#190
Recon'd engine's still smoking,damnit. So at the very least, will need valve stem seals replacing as a precaution, and hope that's the problem.
Missed gear change cost me a shot at first or second in class. Super tight results in class, 0.26 of a second faster would have taken me from fourth to second.
