Page 107 of 107 FirstFirst ... 75797105106107
Results 1,061 to 1,070 of 1070
Thread: Novi's Proletariat Garage
  1. #1061
    Mmmm.... New ignition parts
  2. #1062
    Where are my keys? GB's Avatar
    Birthplace of Speed
    Cake, or death?
  3. #1063
    Indiana
    Its like 5 minutes per coil on the Crown Vic. Plugs add maybe another 5. Intake is drivers side though so different design which makes it easier. (You can do all 8 without pulling it)
    If you can get autozone or advance to check the codes they can tell you which cylinder is out.
    Youll probably spend more time dealing with the intake than changing all the plugs and coils.
  4. #1064
    ^ x2
    Araparts + NGK Platinums = $100 + 3 beers
  5. #1065
    Roger that, I'll look into it and report back.
  6. #1066
    I think maybe NGK plugs are a bad idea. Both the SHO and the XR4Ti always preferred OE Motorcraft plugs, and every experiment off the reservation ended in failure. Not sure if the 4.6l is so sensitive, but it might be worth sticking with OE plugs. Rockauto does carry Motorcraft, FWIW.
  7. #1067
    I usually stick with OE plugs in everything.
  8. #1068
    Good points, especially considering that my wee lil' motor is completely stock.
  9. #1069
    I bet it still runs better than the Hoopra.
  10. #1070
    LoL no way -- the H00pra ran well when I sold it. Leaked oil as bad as the Bananastang does but ran better.
Tags for this Thread
