I'll let you know when it's happening in January sometime. See if you are feeling up to it.
Mebe.
Uncle Jimbo's corn cob pipe!! Check this build thread out if you've got a day free!
Apparently a '94-'98 30mm front sway bar is a great match for the '03-'04 IRS...
Nah, gotta be done and rolling by then. #ready2roar
I tried to take a pic tonight that most clearly showed the RICOCKULOUS amount of wheel gap I'm dealing with prior to installing the springs & dampers:
Mission accomplished.
As long as they were properly stored, you should be fine! And, I think Bilstein will still rebuild their HDs for $100 ea, so even if they aren't perfect you have options down the road. You should be fine!
Good to know! I think I need *one* more element -- Steeda X-2 ball joints. #takin4eva
Oh man, those BJs look like the ones on the Jeep that are a pain to replace. Not looking forward to that job, but you're right, don't take the front end apart without replacing ball joints. You'll just end up back there and regretting you didn't do it all at once! Are bushings part of your update plan?
