No argument here. F20C remains my favorite. Even the rev limiter sounds cooler than all others. Yeah, I hear limiters often.
Today I fired up the MR2 after maybe 2 months of sitting. Been quite busy and not home much. Well actually there was no firing up initially. Dead battery. I put it on the Battery Tender for 6-7 hours. That didn't seem to get me even a dim dome light, much less starter engagement. Needing a car to drive tomorrow (and with the mirror still refusing to stay attached on the Z), I found my stock Z battery, took a couple quick measurements, and determined it should just fit. Group 35 vs Group 24. The larger 35 fits snugly in the MR2 tray. So the car runs.
I hear some gear whine now which I'm fairly certain wasn't there before. Mainly 2nd gear. The car doesn't leak anything. I'm confused, as usual. And thinking about a trans fluid change this winter when I can get around to it. I probably last changed it in 2007 or 2008 (Redline MT90).
It's also only boosting 10psi. Methinks it may be time to perform the annual ignition system replacement, which I haven't done since 2008. The car doesn't see a lot of miles...
Someday I want to go through the motor and make it faster but with stock reliability and smoggability. I figure it's possible - make it a stroker 2.2L, CT20b turbo is undetectable, intercoolers are free, and I should be able to get something like 100rwhp extra with stock injectors and a hidden tune. Uninstall the boost controller and go to stock tune every 2 years. I'd love a quick-spool 400hp in this car but that may be a little far fetched (and lots of cash to do it the right way). Eh, just dreaming at this point. Things you do when you haven't driven one of your cars in a long time... you reconnect with what you'd like out of it.
